*BUG FIXED* Potato Master Selection A5 Bug
geekgarage
Post by geekgarage »
without any master selection set, i set A1-5 and B1-3 to 0. I set all inputs to 0db. Then i select my first input as my USB mic and set output to A1-5 and B1-3
I then go through each master selection and when i get to A4 and adjust input on the mic it adjust the output on A4 as expected but also adjust output for A5. When setting master selection to A5 and i adjust the input for my mic nothing happens.
Same thing if i move the input to hardware input line 2. so i guess in the code, master selection for A4 is replicated to A5 instead of A5 having it's own master selection settings
Issue replicated on secondary sytem
geekgarage
Re: *BUG* Potato Master Selection A5 Bug
is there a github i should post this issue on istead?
could you tell your Voicemeeter version ?
i cannot reproduce this problem.
geekgarage
Hi Vincent, my potato version is 3.0.0.7
geekgarage
Here is a video clip of it
https://streamable.com/a5893
ok, thanks for this video, now i got the problem.
it will be corrected in next update.
geekgarage
Any updates on when the next update is as i'm missing the channel :)
yes, we are expecting to update many things in May...
geekgarage
So any updates as we are now i June?
yes, we are late, but we are on it... sorry for the delay.
