Voice feedback.
mrgusse
Contact:
Voice feedback.
Post by mrgusse »
I know it's easy enough to route your mic to your headset to hear your own voice while talking, but is there any way to adjust the volume for the voice feedback in the headset without changing the output to stream/discord? I just want a small amount of voice feedback so I can hear myself and prevent myself from raising my voice.
Re: Voice feedback.
yes, with Voicemeeter Potato, there is an independent MIX per BUS (see SEL button).
mrgusse
Contact:
Re: Voice feedback.
Post by mrgusse »
Ok, so how does it work? I can click the button it lights up but then what ??
hdpcshow
Re: Voice feedback.
Post by hdpcshow »
You press SEL then you adjust the input volume slider then it will remember that setting on that SEL button.
https://u.teknik.io/W0UaM.mp4
mrgusse
Contact:
Re: Voice feedback.
Post by mrgusse »
So for example....
I have headset on A2, if I push the SEL button and then adjust the volume for microphone on IN#1 it will set it like that? and the output to B2 will not be affected?
*edit *
nevermind, found a tutorial about it
