Greeting CN-Audio forum!
I'm new and looking for helps,
So I'm using studio one 4 as the daw, tc konnekt 48 as audio interface.
I'm looking for a way to stream the audio from my master bus to my android phone. So far, I've successfully stream audio from YouTube and other sources to my phone. However, I can't stream audio from my output 1-2 which is my main monitors.
Please help me with the configuration, thank you and sorry for my English.
Need helps streaming from daw to mobile devices
Re: Need helps streaming from daw to mobile devices
you can VBAN Stream from Voicemeeter output BUS only... so your physical output 1-2 should pass through Voicemeeter.
Hi and thank you for the response! I'm sorry but does that mean it's not possible to stream from physical output?Vincent Burel wrote:you can VBAN Stream from Voicemeeter output BUS only... so your physical output 1-2 should pass through Voicemeeter.
If so can you instruct me further?
Thank you.
