ASIOBridge Hi- Fi Cable Bit Perfect Bit Rates, Sample Rates & Latency
Ient
Post by Ient »
Hi Vincent Burel.
These're my Asiobridge statistics when playing a song using *my DAC( " Schiit Modi Uber" ) ,
I. https://imgur.com/DbAm5Lh
II. https://imgur.com/X81RMtn
i. Based on I. , what're the bit perfect settings for my
1. ASIO Control Panel's-
1.i. Bit Depth, it's 16, 24 & 32 bits options only?
1.ii. Latency?
2. In Control Panel-> Hardware and Sound, " Schiit Modi Uber"'s " Speakers Properties"' bit & Hz/ should I only configure " Hi- Fi Cable Input" ?
ii. Based on II. , am I correct optimal Asiobridge Hi- Fi Max Latency= 1,536smp ?
Thx very much.
Ient
Re: ASIOBridge Hi- Fi Cable Bit Perfect Bit Rates, Sample Rates & Latency
Post by Ient »
Referring to I. , in the manual https://www.vb-audio.com/Cable/VBCABLE_ ... ttings.pdf under Finding Best Latency: it says
" This basic formula is working also for Hi-Fi Cable. "
but it didn't say whether " max buffer size" includes both input & output, in following section it shows a similar situation to mine where input & output is different, but didn't say if it applies to ASIOBridge, in ASIOBridge statistics mid & right column= input & output respectively? , no label? , is it ok for bit perfect audio to put highest max latency, 32768 smp for convenience, as I think the correct max latency's lesser? , I also want your opinion/ facts on bit perfect audio best config for both bit rates & sample rates including control panel's, eg is using higher's no effect/ must exactly same, you didn't say, all above unclear, please answer first post questions only & all these questions'll mostly answered.
If all in this literally page's explained in another manual please tell me.
If for my questions you don't care & don't wanna answer, please easily only say *z.
for ASIO Bridge, i recommend to not go below 256 sample ASIO buffer
(HIFI Cable is based on our previous generation of virtual cable that cannot well support high frequency callback / request).
the MAX Latency is regarding the HIFI-CABLE only and we recommend to keep it as default (7168 samples)... possibly increase it if you are running 192 or more kHz.
HIFI-Cable and ASIO bridge are managing 24 and 32 bit perfect... but the HIFI Cable input and output resolution are pending on applications connected on.
