VB Audio Cable - No Sound
RichardG062
Post by RichardG062 »
I have just re installed (as Administrator) VB Cable and driver on my WIN 10 PC all settings checked and re booted after each but getting no sound. Is there a guide/check list available as to how to overcome this issue?
Thank You
Gwydion
Re: VB Audio Cable - No Sound
Post by Gwydion »
Hey RichardG062. There are so many ways to set up vb audio cable and/or voicemeeter. Maybe tell us what you are trying to do in detail? Also, are you only using VB cable and not voicemeeter?
If you want, you can join my discord and pm to see if I can help. Not trying to build a discord community so much as help people when I can with these sort of issues. Invitation stands if you want to pm me here:
https://discord.gg/7rWy7BT
VB-CABLE is made to connect x2 applications togeter; a Player app to a recorder app.
so in some cases you can get no sound in yoru speaker...
precise your audio path, we will explain why you have no sound... but I guess everybody will save time if you use Voicemeeter instead or with...
