Problem setting up vb-cable with Voicemeeter
Tigron_77
Post by Tigron_77 »
Hello.
I own a Blue Yeti usb microphone. I was trying to get better audio from it using voicemeeter following this tutorial.
https://www.youtube.com/watch?v=IMP-IEfg-yg
When i come to 5.03 in the video I can´t find the WDM: Cable input (vb-audio virtual cable) that he uses in the tutorial.
I´ve installed the vb-cable driver and my computer says it is working. I have only the Blu yeti microphone connected to my computer, no other microphones.
I´ve tried removing the driver and voicemeeter application and then reinstalled everything. It gives me the same result.
zapoqx
Re: Problem setting up vb-cable with Voicemeeter
Post by zapoqx »
That is interesting.
Quick info: I didn't look at the vid.
So VBCable is not showing up at all. What about if you go to the sound control panel itself (not the one in settings)? Does it show up in there as disabled?
