VMP Insert Issue?
Gwydion
VMP Insert Issue?
Post by Gwydion »
Is anyone else having issues with the VMP inserts? I'm trying to connect with Digital Brain Instruments Voxpat 2. I can connect to the insert panel just fine with my VMB but I cannot get it to work in VMP. I realize its still in beta so perhaps its a known issue? Just curious. Thanks in advance.
Re: VMP Insert Issue?
no, but there is voicemeeter potato insert driver (different from banana).
Gwydion
Post by Gwydion »
Thanks, Vincent. I understand there is voicemeeter potato insert driver different from banana but when I try to select it and use it within voxpat 2, I can select the potato drive but it doesn't work and the program doesn't really seem to recognize that insert. If I close down potato and open banana and connect to the banana insert things work just fine. Perhaps its just an issue with the voxpat 2 program and connect with potato.
I guess for now I'll just have to use banana whenever I use voxpat 2. Thanks.
yes maybe a problem ion ASIO init when selecting another ASIO driver in voxpat
... maybe need to restart it ...
you may contact voxpat support, to ask them if they can find out what's going wrong with this driver...
