Tryin' to use voicemeeter on Rocksmith video game, but there is constantly noise.
It's sounds like positive audio feedback or something like this.
https://youtu.be/awoLgf6ew1c
I'm pretty sure that the problem is because of voicemeeter
https://youtu.be/M7RG2xATXDo
Rocksmith via Voicemeeter. Constantly noise.
Re: Rocksmith via Voicemeeter. Constantly noise.
sonud like a re-injection problem... but i see you have focusrite ASIO driver configured with 16 samples buffers... this is not our recommendation (> 128 samples)...
you may read this topic: viewtopic.php?f=6&t=451
konev91
No. The same problem with 128 samples, 256, 512...
But i found solution using a patch for the game.
Thanks anyway.
Thanks anyway.
