Incorrect window position after program restart
Atg
Post by Atg »
Voicemeeter window position offsets a little higher after program restart. Here is demonstration.
Re: Incorrect window position after program restart
i cannot reproduce it.
let me know your Voicemeeter version
Atg
Post by Atg »
3.0.1.0 x64. I have 2 displays, and It looks like window position restores correctly on the main display, but not on the secondary. The video is recorded on the second display. Also Display 2 is located above of Display 1 in Windows "Rearrange multiple displays" option.
unfortunately, we did not tested on secondary monitor... precisions are critical in debugging matter.
ok, you will try the last version 3.0.1.3 and let me know if the problem remain...
i will note it for next update (but it is not planned for the moment).
Atg
Post by Atg »
Actually it related to taskbar located at the top of the screen. After each restart program's window offsets higher and higher and if there is no virtual "space" above it reset position on next restart. I did not tried on 3.0.1.3 yet.
Update: same on 3.0.1.3.
