challenge code will change when re-install windows system everytime
Alou
Post by Alou »
hello there, I almost need to re-install my windows opration system every month due to some reason. But it seems every time when I re-install my system, the challenge code will change to new one and the old response code won't work anymore. I've re-gen the response code once, and no more chance to re-gen it. Does that mean I need to re-buy a new copy of voicemeeter potato when I re-install my system? The hardwares were never changed.
Re: challenge code will change when re-install windows system everytime
Normally the challenge code should not change on Windows re-installation.
you may however contact us on webshop to let us help you on this problem.
In order to solve your problem we recommend:
1- to install lastest voicemeeter Potato version.
2- before re-installing windows : store the file Voicemeeter_ActivationLog.dat (which is "My Documents \ Voicemeeter" folder).
3- After re-installing Windows: recreate the folder My Documents \ Voicemeeter and copy the previously stored Voicemeeter_ActivationLog.dat in...
4- install Voicemeeter Potato again.
if you still have problem with challenge code change, contact us by the webshop contact form (possibly with your Voicemeeter_ActivationLog.dat file attached): https://shop.vb-audio.com/en/contact-us
Alou
Post by Alou »
Vincent Burel wrote:Normally the challenge code should not change on Windows re-installation.
Thanks for the proper answer, I've contact with the supporting team in webshop. Thank you.
