Ability to drag and reposition the macro buttons
I3ordo
Post by I3ordo »
I wish we could drag and drop buttons
relocate them to new positions to make things more tidy on this panel
Re: Ability to drag and reposition the macro buttons
I note your request.
I3ordo
Post by I3ordo »
thank you
xcasxcursex
Post by xcasxcursex »
Great to see this has been noted. In the meantime OP, here's how you can drag and drop them....sort of.
Export the macro settings to an XML file (Alt+Space ... Save button map). Keep this as a backup, and make a copy to work with.
Open the XML file in a text editor. Drag'n'drop the code for each button.
Save the file when you're done.
Load the settings from the new XML file into macrobuttons app (Alt+space ... Load button map)
It's cumbersome, but not as cumbersome as manually recreating the buttons in the position you want them ;)
I3ordo
Post by I3ordo »
Hi again, i am wondering if any updates about this?
ps: where can we track the changes to VM , a github perhaps?
sjc-or
Post by sjc-or »
I'd also like the ability to control their size. I have a lot of them and they take up my full screen and most of the buttons are whitespace with very little text.
Thanks for listening!
I3ordo
Post by I3ordo »
sjc-or wrote: Thu Oct 01, 2020 6:28 am I'd also like the ability to control their size
So u mean, the overall size of all buttons right , not individually bigger ones with smaller ones? yeah that d d be great, the latter would be great too :)
