VoiceMeeter Potato See Through Glitch?
Arcade
Post by Arcade »
Everything is working fine but except when I open the app. Sometimes it becomes see through and i cant click on anything, I attached a screenshot. I was worrying about uninstalling it because i did a lot of work top set it up.
Re: VoiceMeeter Potato See Through Glitch?
i don't see your screenshot.
you can save you settings in xml file before re-installing it.
Arcade
Post by Arcade »
I will try uninstalling like you said. Thank you for the reply. For some reason when I try sending an attachment on the forum it says "Sorry, the board attachment quota has been reached."
Arcade
Post by Arcade »
Could you allow me to post an attachment in this thread @admin?
yes, attachement are allowed normally no ?
Arcade
Post by Arcade »
it just says "Sorry, the board attachment quota has been reached."
Fluxkom
Post by Fluxkom »
I can't attach anything as well, so here is an imgur link:
Not sure, if the behaviour is the same, as for OP.
I have this issue, since I upgraded from banana to potato.
After about 1-3days of having voicemeeter running, it goes into "see through" mode. (See photo above, only the white bar is still visible from the voicemeeter window)
I can still have it on front and click on stuff, I just don't see it anymore. If I click where the A1 output is for example, the dropdown will show up for me to select a device. Rest of voicemeeter stays invisible.
I have to kill the task and restart potato to have it work again for the next days, until it happens again.
Not sure what is wrong there.
Fluxkom
Post by Fluxkom »
Un- and reinstalling everything fixed this for me now.
