I've been using voicemeeter for years and potato specifically for two years in conjunction with reaper (rearoute asio), no issues very stable
But for more than a week now virtual I/O is getting distorted and glitched to hell and back and no amount of re-installs and reboots/configs did anything as suggested in the dedicated topic...
Everything( vb ,rearoute and focusrite wdm and asio drivers) is set on 24bit 44100 hz (settings and drivers); latency is set to default and all combinations have been tested for reassuring purposes and seems set as the xml config I've used successfully for now.
any Idea? reaper and vb mixer still works btw just the I/O is broken and i use it everyday for recording live streaming and voip so it's quite important to my business' well-being ...
Cheers and good day/night to all
