Since purchasing Voicemeeter, I've also picked up an Focusrite Scarlett 6i6. Using the ASIO Focusrite USB 2.0 Audio Driver with Voicemeeter has been extremely straight forward. I've even been able to use the Voicemeeter Insert Virtual ASIO driver in Adobe Audition and Image-Line's minihost, no problems encountered and great performance. It's all just worked absolutely perfectly!
I've got one issue that I'm hoping to resolve. I understand what's going on, I'm just curious if there's a way to tweak Voicemeeter to work around it. The Scarlett 6i6 has two front panel mic/instrument inputs. In my case, I have two microphones attached. Unfortunately, Voicemeeter pairs the 6i6's 6 inputs as stereo pairs, so both mics end up being assigned to Hardware Input 1. I'd really like to break these apart and have one assigned to Input 1, the other to HW Input 2. Ultimately, I want the ability to mute one mic while I keep the other live. This isn't possible right now and instead I have to unplug or turn down the physical gain control. I've figured out how to separate the mics (and all of the other inputs) in the DAW. I'd just like to use Voicemeeter to do it in applications like Skype too. Any advice would be appreciated.
Any chance a future version could have the ability to add even more Hardware Inputs? Not sure if there's a technical limitation, but I'd love to have even more (cause you know, I now find myself with a TON of audio inputs
![Smile :)](./images/smilies/icon_e_smile.gif)
Again, great utility and I'm really looking forward to seeing where it and your other products go in the future!
