CPU Usage Potato vs Banana?
lifewithmatthew
Post by lifewithmatthew »
While I'm guessing a lot of the cpu/memory usage will be dependent on how many devices I'm using and what kind of processing I'm doing on each input/output, what sort of baseline differences can you expect between Potato and Banana in terms of computer resources used?
Re: CPU Usage Potato vs Banana?
in term of CPU load, Potato is expected to be 1.5x to 2x times more heavy maybe.
also pending on BUS MUTE and BUS EQ ON/OFF
audio device are not expected to take too much more CPU
