Good, I'm going to change the video card because the one I have is giving me what I need, but if I change this hardware, it will affect the voicemetter license, in case, how do I prevent the license from being affected?
Thank you
if i switch to gpu, will the voicemeeter license be deactivated?
Re: if i switch to gpu, will the voicemeeter license be deactivated?
normally , if you don't re-install Windows, the challenge code cannot change.
You can possibly store your footprint before as explained there:
viewtopic.php?f=6&t=878
but with the last Potato version 3.0.1.4, nothing can change your challenge code while Voicemeeter is installed and activated.
