can someone kindly represent me schematically how to correctly set Vocemeeter, having a hardware microphone input, a Windows media player input and Zoom?
In particular with this configuration, the volume of the general zoom audio is linked to the volume of the virtual input!
I can't find the correct combination ...
Thank you
How to correctly set basic Vocemeeter with Zoom.
Re: How to correctly set basic Vocemeeter with Zoom.
you may get inspiration from the use case #1 of the user manual (replacing skype by zoom).
https://vb-audio.com/Voicemeeter/Voicem ... Manual.pdf
but this could be better to use Voicemeeter Banana and watch this tutorial directly:
https://youtu.be/nIpt3jF0Nds
