VM Banana problem after re-install of Windows 10
MetaSoc
Post by MetaSoc »
Hi, I have a problem after reinstalling Win 10 (actually downgrading from 2h20 to 1909). After doing it I reinstalled VM Banana, and now after every Win startup I get this "Bad Audio Driver Installation " warning. In the "Check Driver Installation" tool I get this:
OUT WDM Headphones (VIRO Plus) | USB\VID_3299&PID_4E4E&REV_0100&MI_00 | {314ca0c9-fff9-4814-81ef-64a0ea5c58b9} | ICON: C:\WINDOWS\system32\mmres.dll,16
OUT WDM VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO) | VBAudioVMAUXVAIO | {5ec55621-5764-4685-aba7-48a4a42b44c5} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT WDM VoiceMeeter Input (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {e171d304-1d05-40ff-8f09-95f5dbf9b241} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
OUT KS VIRO Plus | USB\VID_3299&PID_4E4E&REV_0100&MI_00 | \\?\usb#vid_3299&pid_4e4e&mi_00#7&2e73e0f7&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
OUT KS VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT MME Headphones (VIRO Plus) | USB\Class_01 | {314ca0c9-fff9-4814-81ef-64a0ea5c58b9} | ICON: C:\WINDOWS\system32\mmres.dll,16
OUT MME VoiceMeeter Aux Input (VB-Audio | VBAudioVMAUXVAIO | {5ec55621-5764-4685-aba7-48a4a42b44c5} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT MME VoiceMeeter Input (VB-Audio Voi | VBAudioVMVAIO | {e171d304-1d05-40ff-8f09-95f5dbf9b241} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
CHECKING VB-Audio Cable A : Not Installed
CHECKING VB-Audio Cable B : Not Installed
*ERROR MME Recording Device not listed.
*ERROR WDM Recording Device not listed.
*ERROR TOTAL FOUND: 2
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
TEST DATE: 2021/05/13 - 19:13:50 (Checker Version 1.0.7.7)
Operating System: WIN 10 64Bits Build: 18363
CONCLUSION: 4 error detected (You may consider re-installing audio drivers)
I tried reinstalling VM Banana etc. but the error is still there. Am I supposed to do something with it or it's some false-positive kinda thing?
Re: VM Banana problem after re-install of Windows 10
Hi. Unfortunately Your message doesn't include the Input devices section so I am not sure this will be the solution:
Please go to Windows Sound settings - Manage sound devices. Scroll down to the bottom and look for VoiceMeeter Output and Aux Output into the Disabled - Input Devices. Try to enable them.
MetaSoc
Post by MetaSoc »
Andres wrote: Tue May 18, 2021 2:01 am Hi. Unfortunately Your message doesn't include the Input devices section so I am not sure this will be the solution:
Thanks for the reply,
sorry, but I'm not quite sure whether you mean Sound Control Panel by "Windows Sound settings". Everything here is enabled and so far I've noticed VM works as it should with OBS, just that annoying warning each PC startup.
Also, I don't exactly know what do you mean by "Your message doesn't include the Input devices section". Is it in VoiceMeeter options or System options?
Hi. I apologize for the confusion. Please consider attaching the complete text of the drver check: In the VB-Audio Device Checker window, right click over the text and select Select All and then right click Copy. Open notepad and paste it. Save the file and attach it to your post.
Windows Sound settings: You can press Windows key + R and type ms-settings:sound in the Run window.
MetaSoc
Post by MetaSoc »
Andres wrote: Tue May 18, 2021 3:36 pm Hi. I apologize for the confusion. Please consider attaching the complete text of the drver check: In the VB-Audio Device Checker window, right click over the text and select Select All and then right click Copy. Open notepad and paste it. Save the file and attach it to your post.
Oh, I see, my bad. Can't attach .txt file so I'm pasting it here.
INPUT DEVICE: 4
IN WDM Microphone (VIRO Plus) | USB\VID_3299&PID_4E4E&REV_0100&MI_00 | {1ea8019e-b2d6-44ad-b973-756f20969b1a} | ICON: %windir%\system32\mmres.dll,-3014
IN KS VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN KS VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN MME Microphone (VIRO Plus) | USB\Class_01 | {1ea8019e-b2d6-44ad-b973-756f20969b1a} | ICON: %windir%\system32\mmres.dll,-3014
OUTPUT DEVICE: 9
TEST DATE: 2021/05/19 - 09:18:31 (Checker Version 1.0.7.7)
MetaSoc
Post by MetaSoc »
As I understand, Voicemeeter Aux Output and Voicemeeter Output are associated with my microphone? If so, I don't really need to use that, as well as I haven't used it earlier (they were most likely disabled) and everything was working without an error message.
Voicemeeter Output & Voicemeeter Aux Output are presented as recording devices.
theses can be used by an application to capture sound outgoing from BUS B1 and BUS B2 respectiviely.
you are not supposed to disable them since they are part of Voicemeeter I/O.
