Hey there!
Maybe I've missed this within the documentation, but is there a way to use MT32 as a multi-channel recorder using the VAC's?
For example, what I'm hoping to do is have 1 stereo track for VAC-A, 1 Stereo for VAC-B, 1 track (doesn't matter if stereo or mono) with VAC-C, and another track (Doesn't matter here either) with VAC-D.  I need the tracks to be recorded and exported separately for mixing.  I also use Voicemeeter Potato, but it seems to congregate the tracks into a single recording.
Is this possible using the MT32?
If not, are there any programs/DAW/Software that you would recommend?
Thanks so much! - Mackenzie
						Multi Channel Recording using VAC's?
Re: Multi Channel Recording using VAC's?
Mutlichannel recording is possible trhough different workflow:
1- The Voicemeeter Integrated Recorder allow to record a BUS in multichannel (up to 8 tracks). This BUS can be in COMPOSITE mode to get 8 different input channels of Voicemeeter. See COMPOSITE MODE in Voicemeeter Banana User Manual: https://vb-audio.com/Voicemeeter/Voicem ... Manual.pdf
2- Connect and ASIO application to Voicemeeter Virtual ASIO driver to get the 8 channel of the related virtual BUS. This BUS can be in COMPOSITE mode to get 8 different input channels of Voicemeeter. See CASE STUDY #3 Voicemeeter Standard User manual: https://vb-audio.com/Voicemeeter/Voicem ... Manual.pdf
3- MT32-SPLITE can also be used like previously discribed, but can be better connected to Voicemeeter Virtual ASIO Insert driver to get all Pre-fader input of Voicemeeter. This is the regular MultiTrack Recorder + Mixing Console workflow, because the recorder can record all inputs, and plays them back inline inside the mixer (as they where coming from the input sources), possibly to make Re-Recording / dubbing / Multi Take Workflow...
				Mack92011
There is a reason I always look at your software first!
Thank you. I'll give this a shot and let you know if I run into any issues. Otherwise, until then, enjoy your weekend.
				Mack92011
This worked PERFECTLY! Voicemeeter and VB for the win.Vincent Burel wrote: ↑Sat Jun 12, 2021 9:13 am Mutlichannel recording is possible trhough different workflow:
