AUX output not working
Bestia_au
Post by Bestia_au »
I been working at this for a while
I have uninstalled and reinstalled both Banana and Potato
And I have done both a few times - but I cant get any sound playing through the AUX channel
Rather then trying upload all the screen shots - here is a link with ALL the screen shots from todays attempt with banana
https://docs.google.com/document/d/1fIH ... sp=sharing
But regardless how ever I install it - its just AUX that doesnt work - when I installed Potato - the third input works with out an issue
When I install VBCable that works - it is just the Aux that isnt working
Device name DESKTOP-E35PBI9
Processor AMD Ryzen 5 1600 Six-Core Processor 3.19 GHz
Installed RAM 16.0 GB
System type 64-bit operating system, x64-based processor
Re: AUX output not working
Voicemeeter Virtual AUX output is fed by the output BUS B2
if you send nothing in B2 (see assignation button on each strip) you will get no audio in AUX output.
Bestia_au
Post by Bestia_au »
I dont think I was clear
This is working - Running through the main channel
https://ibb.co/bbG95ch
This is not working - The only change is pointing the browser at the Aux Input
https://ibb.co/yh7xSp5
xcasxcursex
Post by xcasxcursex »
Usually when this happens, it's been magically muted by something. Check out the 'Levels' tab in the control panel properties for the device, or eartrumpet is a nice pretty way to do it. I literally keep that app handy to check exactly this. It's a pretty common little glitch and a handy tool for the job. Avoid sndvol, or the windows volume app, they will alter your default devices when you check.
Once you're either in the control panel or eartrumpet, you can also confirm that audio is being sent from the browser to the device. In the control panel it's the green meter on the right side of the device list, in eartrumpet it's where the slider is.
If it's not muted, and if sound is coming from the app and you can see it in the meters mentioned above, run VBdevicecheck.exe and see what it reports.
Last up, if you exit voicemeeter, and play the audio in the same way, now the audio sent to that output device (VB AUX input), will come out of the corresponding input device (VB AUX output) and you can now use the 'Listen' tab in windows, select your physical audio output (AMD GPU/XG2705 monitor in your case). So, you go: app -> aux in -> aux out -> listen to this device -> XG2705
The intention of this is to figure out where the audio stops. After we know more about what's happening, it will be easier to stop that from happening... But I'm guessing it's muted ;)
Bestia_au
Post by Bestia_au »
Eartrumpet is showing Audio is being feed to the Aux
Done - Full C&P Below TLDR - CONCLUSION: OK (nothing bad detected)
INPUT DEVICE: 10
IN WDM Headset Microphone (CORSAIR VOID ELITE Wireless Gaming Headset) | USB\VID_1B1C&PID_0A51&REV_0000&MI_00 | {87c39d96-3b3b-4de8-9938-89b95e858e88} | ICON: %windir%\system32\mmres.dll,-3015
IN WDM Microphone (C922 Pro Stream Webcam) | USB\VID_046D&PID_085C&REV_0016&MI_02 | {f0dda4b8-882c-433e-9bbb-bc1a73eecb57} | ICON: %windir%\system32\mmres.dll,-3014
IN WDM VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO) | VBAudioVMAUXVAIO | {1293e36f-c9a3-4715-b058-9bf393599aa6} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-101
IN WDM VoiceMeeter Output (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {834eebbf-0289-4ba6-8426-9789f49b4127} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
IN KS  VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN KS  VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
IN MME Headset Microphone (CORSAIR VOI | usb\vid_1b1c&pid_0a51&mi_00 | {87c39d96-3b3b-4de8-9938-89b95e858e88} | ICON: %windir%\system32\mmres.dll,-3015
IN MME Microphone (C922 Pro Stream Web | USB\Class_01 | {f0dda4b8-882c-433e-9bbb-bc1a73eecb57} | ICON: %windir%\system32\mmres.dll,-3014
IN MME VoiceMeeter Aux Output (VB-Audi | VBAudioVMAUXVAIO | {1293e36f-c9a3-4715-b058-9bf393599aa6} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-101
IN MME VoiceMeeter Output (VB-Audio Vo | VBAudioVMVAIO | {834eebbf-0289-4ba6-8426-9789f49b4127} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-101
OUTPUT DEVICE: 15
OUT WDM 4 - S24C350 (AMD High Definition Audio Device) | HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007 | {519ae3cd-9e98-4cba-bd99-9e858445c165} | ICON: %windir%\system32\mmres.dll,-3017
OUT WDM 5 - XG2705 (AMD High Definition Audio Device) | HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007 | {18418dc4-075e-4494-b21b-c92d7c68ce82} | ICON: %windir%\system32\mmres.dll,-3017
OUT WDM Headset Earphone (CORSAIR VOID ELITE Wireless Gaming Headset) | USB\VID_1B1C&PID_0A51&REV_0000&MI_00 | {15a1566a-d598-44d1-beb5-962202ba3f37} | ICON: %windir%\system32\mmres.dll,-3015
OUT WDM VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO) | VBAudioVMAUXVAIO | {ae8f7d97-67bc-4b7e-aec0-9db86280d616} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT WDM VoiceMeeter Input (VB-Audio VoiceMeeter VAIO) | VBAudioVMVAIO | {53a4d76e-bed3-4282-8d6b-09626f5ce780} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
OUT KS  @System32\drivers\bthhfenum.sys,#2;%1 Hands-Free AG Audio%0
;(audeeo Sheath) | BTHHFENUM\BthHFPAudio | \\?\bthhfenum#bthhfpaudio#9&3a73111e&0&97#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS  Corsair Audio Device | USB\VID_1B1C&PID_0A51&REV_0000&MI_00 | \\?\usb#vid_1b1c&pid_0a51&mi_00#7&2846a853&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
OUT KS  VoiceMeeter Aux vaio | VBAudioVMAUXVAIO | \\?\root#media#0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS  VoiceMeeter vaio | VBAudioVMVAIO | \\?\root#media#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
OUT KS  audeeo Sheath Stereo | BTHENUM\{0000110b-0000-1000-8000-00805f9b34fb}_LOCALMFG&000f | \\?\bthenum#{0000110b-0000-1000-8000-00805f9b34fb}_localmfg&000f#8&1a8d80e&0&fc58fa463b96_c00000000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\src
OUT MME 4 - S24C350 (AMD High Definitio | HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007 | {519ae3cd-9e98-4cba-bd99-9e858445c165} | ICON: %windir%\system32\mmres.dll,-3017
OUT MME 5 - XG2705 (AMD High Definition | HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007 | {18418dc4-075e-4494-b21b-c92d7c68ce82} | ICON: %windir%\system32\mmres.dll,-3017
OUT MME Headset Earphone (CORSAIR VOID  | usb\vid_1b1c&pid_0a51&mi_00 | {15a1566a-d598-44d1-beb5-962202ba3f37} | ICON: %windir%\system32\mmres.dll,-3015
OUT MME VoiceMeeter Aux Input (VB-Audio | VBAudioVMAUXVAIO | {ae8f7d97-67bc-4b7e-aec0-9db86280d616} | ICON: %windir%\system32\Drivers\vbaudio_vmauxvaio64_win10.sys,-100
OUT MME VoiceMeeter Input (VB-Audio Voi | VBAudioVMVAIO | {53a4d76e-bed3-4282-8d6b-09626f5ce780} | ICON: %windir%\system32\Drivers\vbaudio_vmvaio64_win10.sys,-100
CHECKING VB-Audio Cable A : Not Installed
CHECKING VB-Audio Cable B : Not Installed
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
TEST DATE: 2021/07/25 - 21:55:55 (Checker Version 1.0.7.7)
Operating System: WIN 10 64Bits Build: 19042
A hiss to start with and then nothing
xcasxcursex
Bestia_au wrote: Sun Jul 25, 2021 11:06 pm A hiss to start with and then nothing
That's super odd. Normally I would be pointing to the uninstall/reinstall procedure (with all the reboots and such) but honestly you strike me as having tried all the basics already.
I hope Vincent has some idea?
Bestia_au
Post by Bestia_au »
xcasxcursex wrote: Sun Jul 25, 2021 11:56 pm
Thanks anyways - Yeah I have uninstalled and reinstalled - and even tried switching over to potato with the same result
then check Windows Audio parameters:
- Volume mixer (the device can be muted)
- Privacy settings (the device is not allowed)
- Communication options (select DO NOTHING)
Bestia_au
Post by Bestia_au »
Vincent Burel wrote: Mon Jul 26, 2021 12:26 pm then check Windows Audio parameters:
Nope and set to 100
Vincent Burel wrote: Mon Jul 26, 2021 12:26 pm - Privacy settings (the device is not allowed)
Like this?
Vincent Burel wrote: Mon Jul 26, 2021 12:26 pm - Communication options (select DO NOTHING)
No Change
Hi. You could explore the settings of the VoiceMeeter AUX VAIO using the Virtual AUX IO Control Panel. Check both Latency and Max Latency; default latency value is 7168 samples. Using Windows Sound Control Panel - Playback tab - Select VoiceMeeter Aux Input - Right click and select Test from the menu. It should send some tones to the VoiceMeeter AUX and you should see the levels on the Input meeters of the Virtual AUX IO Control Panel.
You can find the Virtual AUX IO Control Panel using the Windows Search box and typing "AUX IO".
You can also join VB-Audio Discord server so we can try to help you in a voice call with screen share which is easy to diagnose your issue.
