Additional outputs not working
StephenCross
Post by StephenCross »
Hi All,
I have a Presonus Firepod with 8 inputs and 8 outputs.
I have enjoyed the Voicemeeter Potato but just updated to the latest version and now my 3 - 8 outputs don't work. See the attachment for the error message.
I also noticed that windows did an update... that might also be the cause.
My issue is this audio interface is discontinued, so the drivers are not able to be updated.
anyone know what the error is and how to fix it?
I also tried changing it over to KS and just get a loud static sound that is not linked to the volume control at all.
thanks!
Re: Additional outputs not working
Hi. Since you are using ASIO for A1 you could try to use PATCH BUS TO A1 ASIO Outputs instead of using WDM or MME at Hardware Out A2, A3 etc.
Just select - remove device selection - from A2, A3 and so on and enable the PATCH.
PATCH BUS TO A1 ASIO Outputs.png (72.44 KiB) Viewed 7295 times
