I just noticed recently that VBAN Receptor on iOS is now being treated as the primary audio source and opening other audio sources like podcasts or music causes it to switch over. My primary usage is using it to listen to my computer audio, while still doing stuff like podcasts on my phone. Is it possible to get this functionality back, or is this the way it has to be going ahead. I think the update 2 days ago caused this change.
I could probably figure out some other solutions if necessary, I just thought I'd ask, because it was a really convenient way to use my desktop audio while not having to fiddle with my pc to change what I'm listening to or pause anything.
VBAN Receptor No Longer Allowing for other audio
Re: VBAN Receptor No Longer Allowing for other audio
you talk about VBAN-Receptor version 1.5 ? and what version did you have before ?
normally the VBAN receptor let new audio app use audio device and go back to VBAN receptor after normally.
Haven't checked back in on this but the mix with audio setting completely fixed this thanks!
