When I press a button to cmd another computer (with no keyboard interaction) I get a weird effect on my keyboard that simulates a CTRL+WIn+ALT depression. My keyboard gets weird and the only way to fix is pressing those keys.
here is the evidence:
My LAN IP is 192.168.1.101
Bug in beta Ver 3.0.2.0 (64)
- WIndows.png (13.56 KiB) Viewed 4231 times
- Vban Config.png (24.9 KiB) Viewed 4231 times
Re: Bug in beta Ver 3.0.2.0 (64)
Found the reason, not a bug, was another button with "CTRL + 2" system.KeyDown without a respectvely key up!
kind regards
kind regards
