@Andres my walkaround atm for pan on BUS Output is to use the EQ for it.
Combine a Highpass and Lowpass on Channel 2 to cancel it out completely for A1 and only Channel 1 (left signal) should remain.
Same on Channel 1 for A3 and only right channel remains.
Here i have it done on A3 to output only chanel 1 (left), so my normal EQ settings for this speaker is still on channel 1.
- Screenshot vbaudio_pan_with_eq.jpg (54.98 KiB) Viewed 19457 times
@Vincent Burel But I really would like have a real PAN Option for the BUS, but because the BUS ist 8 Channel not just stereo this seems to be not done that easy. Maybe a submixer for each BUS, where you can adjust the pregain output levels for channel 1-8 seperately. The Master postgain then would act realative to all the pregain level settings... just an idea.
