Bug report: Ctrl+F10 does not update LED on MIDI controller
JacksonH
Post by JacksonH »
I noticed this bug on the previous version of Voicemeeeter, and found it's still present in the January 2022 update.
I have a Korg nanoKONTROL2 set up to control the 8 strips in Voicemeeter Potato. The M buttons are set to mute each strip with double-feedback enabled.
When I mute/unmute the strip using the GUI, or using the nanoKONTROL, or using the Stream Deck plugin by BarRaider, the LED on the nanoKONTROL updates. The icon on the Stream Deck also updates correctly.
When I mute/unmute the strip using Ctrl+F10, the GUI and the Stream Deck updates correctly, but the LED on the nanoKONTROL does not change.
Here's a short video showing the problem clearly:
https://www.youtube.com/watch?v=1tacGfFolsU
I know it is not Voicemeeter's responsibility to support this exact MIDI controller, but I think it's strange the the GUI and the Stream Deck plugin updates the LED, but the Ctrl+F10 shortcut key does not.
Thanks for your help!
Re: Bug report: Ctrl+F10 does not update LED on MIDI controller
Ok, Mute by shortcut key like CTRL+F10 was not forwarded to MIDI Controller,
it's a minor bug that could have been reported since years, but maybe not very used...
Now it's corrected (will be in next version).
