Can't get Potato "tape" recorder playback to route into DAW
w-u-2-o
Post by w-u-2-o »
I'm assuming the answer is "not possible, not supported". But I'll ask anyway.
I'm using Potato with Reaper DAW. Insert ASIO and Patch Inserts are working great. But I'd like to playback something from the Potato recorder in to the DAW.
Of course there are no patch inserts for the output busses. I'm assuming that is a show stopper? Or is there a way?
Re: Can't get Potato "tape" recorder playback to route into DAW
the tape recorder is playing directly in output BUS , so cannot be captured by a DAW connected to Virtual ASIO insert.
A workaround is to create a loop with VBAN stream targeting local address : 127.0.0.1 and get this stream back in an input (that will go in your DAW through the Virtual ASIO insert driver).
