I recently purchased an XLR microphone and audio interface, mainly to record videos. So I've set up both and 'tuned' them through OBS, which I use to record my videos. However, I am so pleased with the sound quality, that I'd like to use the setup for calling, Zoom, et cetera, as well. I've installed VB-Audio Cable and all works well, except for a huge lag. E.g. I speak and the other person only hears me about 3 seconds later. Now, I've done some digging on the forum, and I'm fairly sure it's a latency issue, but I'm not sure if that's true. Could someone confirm whether or not it is a latency issue and if so, how I should adjust it in order to get rid of the lag, or at least improve it substantially?
P.s. I work on an M1-based Macbook Pro, and I'm fairly sure I can only adjust the Latency in the software. The lowest I can go for the mic to work, is 1536 smp, I think.
close png
