Trouble with Zoom in 2023
mperoutka
Post by mperoutka »
I've spent a few hours trying to combine VBAN with Zoom today. It seems that Zoom 5.13.4 and 5.13.5 both fail to receive output from VBAN 2.0.6.8.
In my specific setup, HW In 1 makes it through to Zoom. HW In 2 doesn't, and VAIO In doesn't.
When I dropped Zoom back to 5.13.3, everything worked.
Anyone else find this? --Matt
Re: Trouble with Zoom in 2023
you mean combine with "Voicemeeter " not with VBAN ?
did you watch this video tutorial: https://youtu.be/nIpt3jF0Nds
mperoutka
Post by mperoutka »
I am traveling for a few days, and I cannot give you a proper reply.
Briefly, I have used VoiceMeeter Banana to mix sounds from W11 apps with voice/music from a PreSonus digital audio interface. In the past, VoiceMeeter Banana did the mixing, Zoom accepted output from VoiceMeeter Banana, and I was happy. This set up has worked for more than a year.
The behavior I described was first noted after the Zoom upgrade. I was able to restore functionality by installing an old version of Zoom. I probably watched the tutorial when I first set things up. I'll watch it again before my next post.
I will make a proper post when I return home and I can document my setup with screen captures. Thank you!
if the problem remains on Voicemeeter virtual output not sent to Zoom, you may read this recent forum topic:
viewtopic.php?f=6&t=1751
