I know that VBCABLE_Setup_x64.exe supports a silent install using the "-i -y" options, but is there an option to not prompt with the "Would you like to install this device software" prompt? This prompt allows the user to Don't Install and I would like for this to not be available or hidden. Let me know if such a command line option is available.
Thank you
Looking for option to install fully silent
Enginero
Re: Looking for option to install fully silent
I mistyped, the option to install silent is "-i -h", like I said I'm looking to see if there is an option to not prompt for "Would you like to install this device software" or if there is any other way around this. ThanksEnginero wrote: ↑Sat Feb 18, 2023 7:26 am I know that VBCABLE_Setup_x64.exe supports a silent install using the "-i -y" options, but is there an option to not prompt with the "Would you like to install this device software" prompt? This prompt allows the user to Don't Install and I would like for this to not be available or hidden. Let me know if such a command line option is available.
Thank you
no, this is a system dialog box , appearing when installing a driver.
