ragnar.jensen wrote: ↑Mon Mar 27, 2023 9:45 am
Is the "Mix" knob on the AudioBox turned fully clock-wise?
If not, it will route some audio directly from its inputs to its outputs.
Hi @ragnar.jensen. Yes. It is fully clockwise in order to get the audio after the Neural DSP plugin.
I have not been able to get this to work and have moved on to a DAW. The mixer in Reaper works fine with the vst of the plugin. Thanks for the help. Cheers, Allan
