[macro] Enable/disable EQ in Bus
py2raf
Post by py2raf »
Hello Vincent / Forum users,
Is there a macro function that enables/disables the EQ in a given bus?
I failed to find it on the VoiceMeeter User Manual - using VM Banana here.
Thanks a lot!
ragnar.jensen
Re: [macro] Enable/disable EQ in Bus
Post by ragnar.jensen »
The function is Bus[ i ].EQ.on
Set to 1 to enable EQ, 0 to disable.
Ragnar
py2raf
Post by py2raf »
Thanks a LOT, Ragnar!!!!
