How to manage patches/Presets
sjc-or
Post by sjc-or »
I know that the documentation probably needs to catch up. I see a Preset list over to the right with a bunch of empty presets. I'm not sure how to apply and manage patches. Can someone summarize?
Re: How to manage patches/Presets
To Define Preset Patch is very simple:
1- Select the preset you want to define.
2- Define a Zone in Matrix,
3- Right Click and select "Store Zone in Selected Preset".
4- you can also add a Zone and build Preset with up to 64x zones.
Then you can use your PRESET Patch in different way (right click on PRESET to get contextual menu).
REM: The preset is automatically stored.
Ade
Post by Ade »
This is looking very impressive Vincent, and presets are the key to midi control of the mix.
Voicemeeter has the ‘hook’ function where I am able to assign the jog wheel of a windows device, such as Logitech keyboard, to a Voicemeeter fader. Is it possible to achieve this kind of assignment in Matrix?
