Hi @all
the driver installation failed under Windows 10 v1909.
I tried to install as admin but get still get exclamation mark. Also tried to remove and add the driver manually without success.
Any solutions?
thank you!!
VB-Audio Matrix VAIO Driver installation issues
klampfenfreak
Re: VB-Audio Matrix VAIO Driver installation issues
yes, apparently it works for Windows 10, version 2004 and later
compatibility problem with Windows Kernel API...
we are currently studying the question... this will be fixed in next version (we found the compatibility problem with ExAllocatePool2).
klampfenfreak
Hi Vincent, thank you for the info,
if I understand right, we will get a fixed version for Win10 v 2004 previous versions?
Any news about a release date, yet?
