Problem with the VBAN protocol
shimatani
Post by shimatani »
Ordinary voicemeeter installed on windows 7 does not receive from other voicemeeter.
I made all the settings and I don't receive the audio from the first voicemeeter, I have 3 voicemeeters on the network and they are all configured, one works and the other doesn't.
What can I do to solve this problem images attached
shimatani
Re: Problem with the VBAN protocol
Post by shimatani »
Before you can say it's about simple rate, I've also done everything the same and it doesn't work
no it's surely about stream name.
you send a stream called "Stream2" to 192.168.0.52
so you must also called "Stream2" on reception.
TIPS: right click on Stream Name to get the list of incoming stream and select it directly.
