HI Guys..
I'm running a Win 7 Ultimate SuperLite with SP1 64 Bit with most of the Bloated Ware Content Removed making a Much Smoother OS on a Proxmox Blade Server for some Ham Radio based Linking Between ASL and Mumble Client and ASL and Zello..
Win 10 and 11 uses way too much Storage Space requiring constant additional Space for all the Updates and is a Tad Overkill for what I'm using it for.
I have Installed Both A/B and C/D and although the A/B Installed Flawless the C/D has the Driver Signing Issue where it wont Run..
I am Curious if A/B runs then why would only C/D have the Signing Issue..
As this is a Cut Down Version of the Win 7 OS Running an Update is not an Option unless I can install the Update file as a Offline Download.
Has anyone else Fixed this Issue so I can avoid going down the same Rabbit Hole ?..
Thanks
Rob..
Windows 7 Ultra Lite Virtual Machine C/D Driver
memorex
Re: Windows 7 Ultra Lite Virtual Machine C/D Driver
no, there is no signature issue on C+D, they are signed with a more recent algorithm than A+B, so the problem is located on your Win7 O/S missing some component to understand the signature.
more info on this topic: viewtopic.php?t=669
