My VoiceMeeter has missing icon in the task bar and I don't know why. Issue appeared this week. Do you know how to fix it?
https://i.imgur.com/ZzX1aFv.png
VoiceMeeter missing icon in task bar
Re: VoiceMeeter missing icon in task bar
could you be more precise? what icon? in system tray ? what is your Voicemeeter version ?
MrKoddy
the icon you have once you run the app or the one you can pin in the task bar
what is your voicemeeter version ?
could you post a screenshot ?
MrKoddy
Banana 2.1.1.3
I didn't update I don't know why it is the only app which lost its taskbar icon
Here an imgur image with my app and task bar
https://imgur.com/a/82RZ3Rx
edit: I updated to latest version still a balnk icon for voicemeeter only in the task bar
well, i've no idea about how it is possible. never heard about before... have to wait for more report on this...
MrKoddy
I found a solution. I created a shortcut on desktop then opened the app through the desktop's shortcut and my task bar icon was back!
