Hi All
Hoping someone might be able to help me please. It's just started happening that when opening Coconut, VBan is switched off and routings don't reappear when I switch it back on. If I enter the Ip addresses again, then some of the routings reappear (but not all) and not with colour preferences.
Has anyone come across this?
Many thanks
Jon
Vban switches off..
Re: Vban switches off..
We have no report on this problem.
What is your Voicemeeter version ?
It's Coconut 64 bit version 2.0.1.1. I've reinstalled but same issue.
Many thanks
Jon
Many thanks
Jon
could you test the latest version currently in beta on our Discord forum ?
Hi
Im on the beta page on discord but cant see anything about Coconut
Can you point me to it please?
Many thanks
Jon
Many thanks
Jon
Hi again
Ive just bought another Potato license but it's not letting me enter the challenge code. The challenge code on the email receipt is different from the pop up box and cant be edited/changed.
My address is leedsmusicproduction@gmail.com
Many thanks
Jon
Many thanks
Jon
you can get latest Matrix Coconut in Discord #testing channel (get the Beta tester role in #role).
For question about activation code, you may contact us by the webshop contact form:
https://shop.vb-audio.com/en/contact-us
Hi
Just installed the beta but same result
Thanks
Jon
Thanks
Jon
Hi Vincent
Please can I ask if there may be another fix?
Many thanks
Jon
Many thanks
Jon
Hi Vincent
Many thanks
Jon
Many thanks
Jon
