Macro Button Window Position Issue
peejaygee
Post by peejaygee »
Looking for some help.
I'd like the Macro Buttons Window to appear on my primary monitor not one of my secondary ones, ideally in a fixed position.
Is there a config or registry setting I can change, or an option in the 'Menu' I'm overlooking?
Thanks for your time.
Regards
PJ.
peejaygee
Re: Macro Button Window Position Issue
Post by peejaygee »
I think I have sorta of mastered it by saving 'Button Map' but the X pos isn't sticking, I put it bottom right corner, and it appears over to the left, I'm going to edit the XML and see if I can manually move it.
peejaygee
Post by peejaygee »
Nope, I tried to manually edit the file and restart and it still appears in this location.
Is it possible to have it right side on start up?
you must use the latest version of Macro Buttons (1.1.2.0) and check if the problem remains.
peejaygee
Post by peejaygee »
Still the same issue with 1.1.2.0 after I updated to the latest Dec 2024 version.
peejaygee
Post by peejaygee »
Maybe I did fix it, I press the CTRL and the X, like I used to do with Internet Explorer back in the day, the next restart, it stayed in the bottom right corner of the window?
