I have VB Banana installed, and had VB-Cable A and B working.
I read somewhere else that VB-Cable installation can break when Windows Updates.
I read about the proposed deinstallation and re-installation of all VB software, which I did.
But no such luck.
VB Banana works as it should, just VB-Cable does not work anymore, horrible distortion only.
Anyone?
VB-Cable disfunction since updated Windows 11 Version 24H2 (0S Build 26100.4652)
Re: VB-Cable disfunction since updated Windows 11 Version 24H2 (0S Build 26100.4652)
You may install latest Voicemeeter (2.1.1.9) and VB-CABLE version (pack 45).
