While setting up a stereo in another room I decided to use VBAN with an older cellphone to send the audio from my PC in the bedroom as the audio from the wireless HDMI extender I used isn't all that great.
Using a signal generator app on my PC I discovered the output at 20kHz causes the input level in VBAN receptor to drop by 1 bar on both channels.
That cellphone has a 44.1kHz sampling rate according to VBAN Receptor.
I tried my new cellphone which has a 48kHz sampling rate according to VBAN Receptor and same issue.
I can connect an oscilloscope to a quality bluetooth receiver that I verified is flat to 20kHz using an audio generator on my phone and can see the drop in output.
I even tried a nearly 2 year old Windows 11 PC and have the same issue.
The sampling rate from VBAN is 24 bit 96kHz. The main stream sampling rate is 24 bit 192kHz.
I verified that it wasn't the app by connecting the scope to a quality sound card and no drop in audio at 20kHz.
To verify it isn't VBAN Receptor I sent audio to another PC using VBAN and same problem.
Upgrading to the latest Voicemeeter Banana version didn't fix it.
Any reason why VBAN would be causing this issue?
VBAN problem
Re: VBAN problem
if there is a SRC (samplerate converter) in the audio path, the frequency response might be slightly modified (especially on 20 Khz).
