Problem on win11 23H2
TomyN
Post by TomyN »
I've been using vb-virtual cable for a long time without any problem.
Now I tried to use it on my new laptop running win11 23H2, where it locks applications when trying to start capture (via wsaapi or waveInXX functions).
The error log reports
0001 Exception Thread: ID=12600; Name=MAIN; Wait Chain=Blocked waiting for ALPC owned by thread [ $0000 / 0 ] -> thread -> ALPC "\RPC Control\AudioClientRpc" -> process: [ $0EF0 / 3824 ] is PID only;
This happens only when the virtual cable is selected as I/O device.
The installation check reports outdated version of either vb-cable or of the checker.
I tried uninstall /reinstall for serveral times without any success.
Re: Problem on win11 23H2
did you install the latest VB-CABLE package ?
New Package: VBCABLE_Driver_Pack45.zip
(1.29 MB - OCT 2024 / XP to WIN11 32/64 bits/Arm64)
www.vb-cable.com
TomyN
Post by TomyN »
I used the installer from the website, which I've downloaded yesterday.
Filecreation (as reported by windows) and version
vbaudio_cable64_win10.sys 08.10.2024 - 10.0.10011.16384
ok, there is no problem with this package and win11.
Could you post a screenshot of your Windows Device Manager, section "Audio, Video and Game Controllers" ?
