How to start with Voicemeeter ? (4 steps).
All Guides to explain how to do everything with Voicemeeter...
Locked
Once you have installed Voicemeeter and reboot your computer. You have to run Voicemeeter and configure it.
STEP -1- Select Voicemeeter Virtual Input as default playback device.
Then all your PC Sound (Browsers, Spotify, Game, Discord, Zoom...) will come in Voicemeeter Virtual Input by default.
STEP -2- Select your main output device for A1 BUS
To monitor your audio you need to select an output audio device for output BUS A1. Click on A1 button to open the audio device selector and chose your best audio device or the one you are always using.
Then you can see your PC Sound coming in Voicemeeter Virtual input and going out to your A BUS (your output device) and also into B BUS if B Button is switched ON:
STEP -3- Run Voicemeeter on Windows Startup
To make Voicemeeter your Audio Control Center for Windows, you have to be sure it runs on Windows startup.
Just go in Voicemeeter Menu to set "Run on Windows Startup" option and "System Tray", then Voicemeeter will go in system tray if you close it (instead of closing the application).
REM: Since your default playback device is Voicemeeter Virtual Input, Voicemeeter have to run to process it and forward ti to your output audio device.
STEP -4- Select your microphone as input strip 1
If you want to take advantage of Voicemeeter built in Fx, especially the Color Panel and Audibility knob to improve your microphone sound, you may select your input device for strip 1 just by clicking on the "select input device" area:
So now you can manage your microphone in Voicemeeter, apply Fx, manage Gain and routing though A/B Buttons. Like on real mixing console.
BUS A is your monitoring (your audio device) BUS B is relying to the virtual output B1 of Voicemeeter that can be used by any capture or communication application willing to get audio from Voicemeeter.
Re: How to start with Voicemeeter ? (4 steps).
Some additional official Video Tutorial on VB-Audio Youtube Channel:
- How to setup Voicemeeter Standard: https://youtu.be/ZXKDzYXS60o
- How to setup Voicemeeter Banana: https://youtu.be/qIfnU97c1pQ
- How to setup Voicemeeter Potato: https://youtu.be/qM3-hTEyo7A
Locked
