How to connect 2x Bluetooth speakers with Voicemeeter (5 Steps)
All Guides to explain how to do everything with Voicemeeter...
Locked
To connect 2x Bluetooth speakers to Voicemeeter, they must both appeared as different playback audio device in your system. Usually a single Bluetooth adapter is not able to manage more than one audio stream, so cannot use 2x Bluetooth device in the same time. That's why we do this guide with a second Bluetooth adapter: the Sennheiser BTD 600.
So we have 2x Bluetooth adapters, the one built in the PC and the Sennheiser one connected on USB port.
Step-1- appearing Bluetooth devices
We first connect our Klipsch Austin speaker to the PC built in Bluetooth adapter so the audio device is shown as Klipsch Austin Headset (it also provide a microphone).
Secondly we plug the Sennheiser BTD 600 that will appear as audio device called BTD 600 (whatever the Bluetooth device connected to). So now you have to connect your other Bluetooth speaker to the Sennheiser BTD 600. We use the JBL GO Essential.
Step -2- Check what is your default playback device
When plugin new audio adapter (like the BTD600) or when appearing Bluetooth device, Windows can change the default playback device automatically to select the last connected one.
But we want to keep Voicemeeter input as default playback device.
Tips: right click on Audio Map button to get access to all Windows Audio settings dialog box
Step -3- Audio Device Selection in Voicemeeter
You can select a Bluetooth device as output A1 but if disconnected Voicemeeter will simply stop running, because output A1 defines the master stream. That's why we recommend to select your Bluetooth audio device for output A2 and A3 instead.
For A1 , you can select nothing as we did to get the internal master clock as main stream. So if one of your Bluetooth speaker is disconnected, Voicemeeter is still running and you can still hear the sound on the other speaker.
If both Bluetooth Speakers are disconnected, you will hear nothing but Voicemeeter will continue to run and you will be able to check audio signal in moving meter bars.
Other solution is to select an audio device as output A1 for monitoring (the one built in your motherboard for example, so cannot be disconnected).
Voicemeeter selector will display output audio device as they are define by the system.
The built in Bluetooth adapter will possibly display the name of your connected speaker (here the Klipsch Austin).
The second Bluetooth adapter will appear directly as an Audio Device (here 2- BTD 600) whatever the Bluetooth device connected to it.
Step -4- BUS Mode
You music Strip will have to be assigned to BUS A2 and BUS A3 to send audio to both connected Bluetooth device.
Voicemeeter BUS Mode is offering LEFT ONLY and RIGHT ONLY to spread your stereo sound on two different audio device. This is allowing to turn your 2 Bluetooth speakers setup in a stereo speaker setup!
Step -5- Latency & synchronization
It's not possible to synchronize strictly 2 different audio device but we can reduce the latency to improve the synchronization between two Bluetooth speakers.
in our case we first set the internal master clock buffering to 256 (setting the main audio stream with a 5 ms buffering).
Secondly, we changed the WDM buffering size to 384 samples (instead of 512) that is usually well accepted by WDM devices.
Monitoring Synchro Delay
If you hear an obvious delay on one Bluetooth speaker compared to other one, you can use the Monitoring Synchro Delay option (in System settings Dialog box) to add delay to the one in advance. for example 10 or 20ms.
Behavior of the Bluetooth adapter:
Built in Bluetooth adapter will make appear the connected audio device in the playback audio device list. This is nice, but if disconnected, this device disappears and Voicemeeter will display it in red (meaning you will need to Restart Audio Engine when it will be connected again).
Second Bluetooth adapter, also appears as audio device but is not pending on the connected Bluetooth device. It is always shown in the audio playback device list as BTD 600. So Voicemeeter consider this device works whatever the connected Bluetooth speaker. That is finally more practical to manage, because you do not need to restart audio engine on Voicemeeter.
Locked
