Persistent ~200 ms audio/video synchronization delay through Voicemeeter Potato
JoinLight
Post by JoinLight »
I'm experiencing a consistent audio/video synchronization problem when playing local movie files through Voicemeeter Potato.
System
• Windows 11, build 26200
• Intel Core i9-11900KF, 64 GB RAM
• NVIDIA GTX 1050 Ti
• Voicemeeter Potato 3.1.3.0 (64-bit)
• VB-Audio Voicemeeter VAIO driver 3.4.1.9
• Samsung UN58NU7100 TV connected via HDMI
Problem:
VLC, MPC-HC, and Windows Media Player all require -200 ms audio synchronization compensation when playing a movie locally from my PC. They all require -400 when playing a video file recorded from a Zoom session. The audio is routed through Voicemeeter to the Samsung TV.
Important comparison tests:
1. Setting Windows output directly to Samsung (NVIDIA High Definition Audio) and turning Off Audio Enhancements produces perfectly synchronized audio and video.
2. Playing the same movie through PC headphones also produces perfect synchronization.
3. A Lenovo laptop connected to the same Samsung TV, using the same movie, plays in perfect synchronization without adjustment.
4. The problem returns when Windows output is changed to Voicemeeter Input. This selection in Windows Sound settings does not have the option for Audio Enhancements like the Samsung TV has.
Voicemeeter configuration:
• A1: Samsung (NVIDIA High Definition Audio), WDM
• A1 sample rate: 48,000 Hz
• A1 buffer: 512 samples
• A1 channels: 2
• A1 resolution: 24-bit
• VAIO input: 24-bit, 48,000 Hz
• VAIO internal latency setting: 7,168 samples
• Reducing VAIO latency to 3,072 samples made no audible difference.
• VAIO Sync Soft/Strict test made no difference.
• WDM buffer 512/256 test made no difference.
• Physical output synchronization delays A1–A5: 0.00 ms.
VAIO Control Panel readings:
• Selected I/O: 6
• Latency: 7,168
• Max Latency: 7,168
• Pull loss: 5,869 (does not increase during playback)
• Push loss: 0
• Timer glitch: 0
• Input DMA errors: 0 / 0
• Output DMA errors: 0 / 0
Other tests:
• Updated NVIDIA graphics and HD Audio drivers; no improvement.
• Updated VB-Audio virtual drivers; no improvement.
• Changed TV audio settings and HDMI cables; no improvement.
• Tested VLC and MPC-HC; same problem.
My question:
Can you help identify why the Voicemeeter audio path introduces a consistent 200/400 ms synchronization offset when direct HDMI playback is perfectly synchronized?
I would particularly appreciate guidance on diagnosing the VAIO 6 to A1 WDM output path, and whether there is a known issue or setting that could cause this behavior.
I need to retain Voicemeeter because I use its B1/B2 routing to send audio to Zoom. I updated Voicemeeter Potato and the Virtual audio drivers Nov. 22 to the latest versions available.
Thank you.
Re: Persistent ~200 ms audio/video synchronization delay through Voicemeeter Potato
Voicemeeter cannot introduce such amount of latency.
With A1 buffer set to 512 sample, it makes 10.6ms at 48 kHz.
the VAIO even with 7168 sample internal latency, can generate 60ms latency max (usually in reality <30ms).
to get more help, you mays post screenshot of Voicemeeter and its system settings dialog box.
JoinLight
Post by JoinLight »
I have attached the screenshot of my VMP System Settings.
VMP System Settings.png (165.15 KiB) Viewed 43 times
JoinLight
Post by JoinLight »
When I hold a Zoom session with the audio going through VMP, and record it with the Zoom recorder, I have a -400 ms sync offset.
400ms is not possible in Voicemeeter.
to measure a latency with a recorder , you must record the source before entering in DSP and the result coming from the DSP (here the DSP is Voicemeeter).
to understand more your configuration, you may post a screenshot of Voicemeeter and explain what is your source, entering where in Voicemeeter and what is your target (where are you hearing the sound).
