Potato audio drop out
mxdog
Post by mxdog »
Not sure if this is a bug or just my system.
I use potato for the obvious reasons to switch and listen to audio on different devices. in my case I have 3 monitors/tv's a number of bluetooth and radio headphones, a stereo i get input from and occasionally output to on the computers line in and out . The monitors and windows system have Realtek on the MB and Nvidia drivers for the graphics card. My trouble is if i set all 5 playback devices 3 monitors and a bluetooth speaker and a bluetooth headphone ( or combinations thereof ) , anytime any or all of them are offline playback stutters pretty much in time with the hardware out list blinking red. The program never seems to give up looking for the devices and in the case of the monitors occasionally doesn't even see them when turned back on until all the devices are once again online. I just tried to record the stutter and the recorder resets also when devices are offline. It is almost like the program does a complete reset ever program cycle they are offline.
Is there anyway to fix this on my end ? If not can the program time out looking for these offline devices to stop the resets so the stuttering stops? It is a royal pain to have to add and remove devices every time i want to turn my headphones on or off or the monitors go to standby and drop out. it was a pain to even get sound working because of the NVidia driver when they go to standby.
2026-11-26 204451.png (22.16 KiB) Viewed 37 times
Re: Potato audio drop out
according your screenshot your device selected as output A1 does not run and you have the "auto restart audio engine " option activated (that you might disable to avoid such case). So Voicemeeter restart audio engine every 5 second until your A1 selected device run (or is reconnected).
You may select nothing as output A1 (to use internal clock) or select a motherboard audio device (never disconnected).
mxdog
Post by mxdog »
that did it, those i think where set by default ?
Thank you !
