ok, all seems to be correct , but nothing is connected to VB-CABLE output like the windows LISTEN option was not working.
maybe try to uncheck it and recheck it or uncheck it and reboot, and recheck it... there is something not normal.
you can also test the VB-CABLE output by using a recording app (voice recorder or Audacity)...
Can't hear anything after installing on Win10
OnlyOne
Re: Can't hear anything after installing on Win10
Sorry, had some other technical difficulties that I had to attend to before coming back to this.Vincent Burel wrote: ↑Tue Sep 09, 2025 7:57 pm ok, all seems to be correct , but nothing is connected to VB-CABLE output like the windows LISTEN option was not working.
Anyway, rechecking it and rebooting didn't work, unless I misunderstood something. You mean set my input and output devices to what I normally set them to and then back to the VB-Audio input/output devices in Sound settings?
I did that and still nothing. I can't record with any recording app, they record nothing. Audacity produces this error:
"timestamp": 1762451347,
"event_id": "55b8472de3112d4f87315ea192fcb974",
"platform": "native",
"release": "audacity@3.7.0",
"contexts": {
"os": {
"type": "os",
"name": "Windows",
"version": "10.0.19044"
"exception": {
"values": [
"type": "Error",
"value": "Error opening recording device.\nError code: -9999 Unanticipated host error.",
"mechanism": {
"type": "runtime_error",
"handled": false
OnlyOne
I finally got this to work, it turns out Windows 10 microphone privacy settings overrides the sound settings and prevent apps from accessing the microphone, which means any kind of recording device, not just a literal mic. Stereo Mix still doesn't work so it's still a mystery what's going on with this damn thing but now that I got your driver to work, it's not as important. I can record now!
Ok! WINDOW PRIVACY SETTINGS related to microphone, right!
this option can be activated after a Windows update and be surprising so.
OnlyOne
Yes. Start > Settings > Privacy > Microphone and make sure it says "Microphone access for this device is on", if not then change it.Vincent Burel wrote: ↑Tue Dec 02, 2025 8:48 pm Ok! WINDOW PRIVACY SETTINGS related to microphone, right!
This isn't the first time Microcock makes things intentionally ambiguous and complicated. How would any normal person guess that a setting about microphone access has anything to do with playback access? I guess the same way someone was supposed to guess that to toggle Autocomplete functionality for Windows Explorer, you had to open Internet Explorer and dig around its settings. Fucking ridiculous.
