Re: Hardware Input 1 = Mic Input freezed after a while.
Posted: Mon Feb 05, 2018 7:56 am
you can also try another interface: WDM, KS or MMEprettynice wrote:Again. Mic stopped after ca. 30 minutes working with the new buffer settings.
Will try another USB Slot now...
this problem is pending on system (or USB device, or driver or Windows management).
REM: for streaming , you have to validate your configuration on a significant duration... for example 12 or 24 hours.
it's a mandatory task to do on Windows to be sure that the configuration works.
