Page 2 of 2
Re: [Potato] How to use and monitor reverb
Posted: Fri Dec 28, 2018 5:27 pm
by JBP
If you care for latency then best choice is to use VAIO3 ASIO Input as output in Audition!
Not any VB Cable!
Use Cables only if you cannot use VAIO (ASIO)!
Or (in the future when you will be more familiar with Potato) you use Potato Hardware Input for your microphone in combination with Potato ASIO Insert to add external FX processing (VST, Audition).
