Page 2 of 2
Re: Audio Issues While Streaming
Posted: Thu Dec 27, 2018 10:22 am
OBS get audio from Voicemeeter VAIO (Output BUS B1)
but 4 other sources too,
so you may check that there is no conflict there, and no redundancy...
Posted: Thu Dec 27, 2018 1:46 pm
by stealth1192
So where would the problem be coming from?
by stealth1192
Also I really appreciate the help. I know I'm bugging a lot I just want this fixed. ;^;
Posted: Thu Dec 27, 2018 1:47 pm
by stealth1192
Also would it be a good idea to just uninstall everything and start from scratch?
Posted: Thu Dec 27, 2018 6:23 pm
no, re-installation is no required, but re-configuration audio streams from scratch, by validated step, should help surely!
Posted: Thu Dec 27, 2018 7:55 pm
by stealth1192
Vincent Burel wrote:re-configuration audio streams from scratch, by validated step, should help surely!
What do you mean by this?
Posted: Fri Dec 28, 2018 5:39 pm
by JBP
Have you read this important sticky thread:
viewtopic.php?f=6&t=442
Posted: Fri Dec 28, 2018 6:21 pm
by stealth1192
I've read the thread and my audio is fine on my end but it's the streaming end where it's all messed up.
Posted: Tue Jan 08, 2019 9:50 am
it means you connect first thing, and you check it works ok...
you connect a second thing, and yout check it works ok
and so on...
if you get a problem, you will see on which step it appears, and will understand it and correct it.
