Incoming Streams - None
sjc-or
Re: Incoming Streams - None
Post by sjc-or »
Yes, maybe it is a flakey adapter on my main computer. I switched temporarily to WiFi but the problem persisted, however it uses the same adapter card for both WiFi and ethernet. Even tried downloading the latest driver for the NIC.
sjc-or
Post by sjc-or »
Well, I replaced the network card and that didn't fix it either. I'm stumped
no, you may change the ethernet switch or/and cable.
we already got the case where the switch simply dies
or/and
the case where the ethernet cable connector was not well plugged (because not good quality connector).
sjc-or
Post by sjc-or »
Yes I had already changed the switch and the cable as well.
Tomorrow, I'm going to explore this:
https://social.technet.microsoft.com/Fo ... dows-10-os
Steve
well, just took a look but i don't think it is the problem (also we don't use multicast mode).
you may try with another PC (replacing the 134 one, the one not receiving audio stream) - to see what's happening.
or did you try to send audio to another device (iPhone / Android) with VBAN-Receptor Lite ?
sjc-or
Post by sjc-or »
No but my computer did this Windows update this morning and everything started working again. So I have to assume Microsoft Broke it a week or two ago and fixed it with this update
https://support.microsoft.com/en-us/top ... 8ed227b0aa
It looks like there was a cumulative update 20H2 also done but for some reason it doesn't show in the history but that might also have fixed it as the updates happened both this morning.
incredible :-) next decade is promising...
sjc-or
Post by sjc-or »
I spoke too soon. After reboot, it is dead again.
sjc-or
Post by sjc-or »
OK, back now Feature Update to Windows 10, version 21H2
Now that is is working, I think I will turn automatic updates off on both PCs
sjc-or
Post by sjc-or »
Rats, it was working a while ago and I reboot and now it is not working. I still have updates disabled so not sure what is going on.
